RossB92's avatar
RossB92
[Solved] Can't Change Security Settings on WNDR3700
Hello,
I am trying to add a password to my WiFi security on my WNDR3700, but for some reason, I cannot. When I login to my router and attempt to change it, the setting won't even move. It's just stuck on "none" and won't move to any other type of security. I've tried resetting and unplugging and all the usual stuff but nothing seems to work. Any help would be greatly appreciated. Thanks!
  • Figured it out. Somehow my router had gotten put on repeating mode so I was unable to change the password!
1 Reply
