joem7006
Aug 10, 2015Follower
something is extremely fishy!
need some help please!! i have a netgear N300 wireless router (WNR2000). recently i have had some unexplained intrusions such as someone changed my router name to: suck_my_d!#k, you get the point. ...
- Aug 11, 2015
If it was my router, I would take the router offline reflash to factory and reconfig. Make sure you use strong passphrase (for wifi SSID's) and a strong router login password. Use different SSID's, etc.. I have added a link for tips for creating passwords and passphrases here. Don't give out your router password or passphrase. Always change the default passwords, never leave anything with default passwords enabled.
DebbyKay
Aug 17, 2015Aspirant
I have been searching for help for hours on the internet. All I want to do is to change the password on my netgear N300 wireless router. My 76 yr old mom gave out the password. All websites listed in the user manual from Netgear is no longer valid and direct you to a foreign site that wants $99 to help. I'd rather throw it away and buy another brand than pay $99 to change the password. Any suggestions?
Babylon5
Aug 18, 2015NETGEAR Employee Retired
That sounds more like a problem with the PC than the router, have you tried other PCs on that network? There are plenty of anti-hijack tools on the Internet e.g. https://support.norton.com/sp/en/uk/home/current/solutions/kb20100811171926EN_EndUserProfile_en_us
If you are still convinced that it is the router that has been compromised then try factory resetting it, but note that a factory reset sets everything back to default settings and you will have to set up the router again. I also suggest that when you are back to a happy state, you save the router settings to a backup file if you have not already done so.
