Jmztaylor
Feb 13, 2016Aspirant
Starting port number must be less than 65535
With this setting, I get that error message when applying. No matter what number I put in the port boxes it always errors out this way. WNDR3400V2 is the model number. On the latest firmware available.
Hi Jmztaylor I didn't get the same error message. Try to factory reset and reconfigure.
- JmztaylorAspirant
That fixed it. Thanks
- JmztaylorAspirant
Actually, I found the issue. If you change the LAN IP address is when this issue occurs. If you change the third octet. And its impossible to change again without factory reset.
- ElaineMNETGEAR Employee Retired
That's strange and that shouldn't happen.
I was able to change on mine no problems.
But glad to hear that you were able to save the settings.
