rkrzewski's avatar
Jul 08, 2016
Static routing: problem reaching host on local network from router's WAN side
I'm having trouble setting up routing in a small office network. I've prepared a diagram of the topology https://drive.google.com/file/d/0B0PjGlcEN6DDV3BpNHJWTEdaWmM/view
Few words of explaination:
Server A acts as main gateway, firewall and VPN access point for the office.
Both server A and B are running Linux and im using iptables and iproute2 tools to manage their networking stack.
Virtual server C is running inside a KVM/Qemu virtual machine on Server B.
Server B is connected to N750 router on a wired connection, Client 1 (my workstation) is connected using WiFi.
Static routes for 192.168.123.0/24 network are established on Server A and N750 router specifying 192.168.2.2 and 192.168.1.10 as next hop respectively.
The route on N750 is NOT marked as private and has metric of 2.
What works:
Virtual server C can reach the Internet (both outgoing and returning packets are routed properly).
Client 1, Sever A and B can reach one another and Internet hosts without issues.
Client 1 and Server B can reach Virtual server C without problems.
What doesn't work:
1) When trying to connect to Virtual Server C from Server A, traffic ends up on Server's B own interface instead!
2) Also I'm unable to connect from Virtual server C to Server A (this is not critical, but I'm mentioning it in case it provides some clue)
When investigating the problem I found out that this affects all IP traffic and I was using SSH as a probe. I have added logging clauses to nat/PREROUTING, nat/POSTROUTING and filter/INPUT iptables chains on Server A and Server B tracking SYN packets on TCP/22.
When trying to reach C from Client 1 with ssh I see:
PREROUTING IN=eth0 OUT= src=192.168.1.100 DST=192.168.123.200 on B
POSTROUTING IN= OUT=virbr0 src=192.168.1.100 DST=192.168.123.200 on B
And ssh opens a session on C, as expected.
When trying to reach C from A with ssh I see:
POSTROUTING IN= OUT=eth1 src=192.168.2.1 DST=192.168.123.200 on A
PREROUTING IN=eth0 OUT= src=192.168.2.1 DST=192.168.1.10 on B
INPUT IN=eth0 OUT= src=192.168.2.1 DST=192.168.1.10 on B
And ssh opens session on B, unexpectedly.
When trying to reach A from B I see:
POSTROUTING IN= OUT=eth0 src=192.168.1.10 DST=192.168.2.1 on B
PREROUTING IN=eth1 OUT= src=192.168.2.2 DST=192.168.2.1 on A
INPUT IN=eth1 OUT= src=192.168.2.2 DST=192.168.2.1 on A
And ssh opens session on A, as expected
When trying to reach A from C I see:
POSTROUTING IN= OUT=eth0 PHYSIN=vnet0 src=192.168.123.200 DST=192.168.2.1 on B
and nothing on A (SYN packet does not seem to reach it at all)
It appears to me that when the static route is applied to the packets coming from WAN side, the destination IP is overwritten with hext hop IP.
I went through admin interface of N750 and the users manual but came back empty handed. I also read several routing related threads on this forum, but I wasn't able to find anything relevant.
While I'm able to work around this problem by designating B as the default DMZ server and setting up DNAT on specific ports at B, I would much rather resolve this routing problem to have a simple and sane setup.
Any help is appreciated!
  • Do you have port forwarding set up?  Otherwise, how can A get past the firewall on the WNDR4300?
    I suspect there are two things working against you.
    1. WNDR4300 is performing NAT, so it's going to rewrite IP addresses.
    2. Stock firmware will only NAT IP addresses on its directly connect subnet.  In your case, it will not NAT 192.168.123.0/24 traffic.
    You should install DD-WRT on your WNDR4300.  Then you can disable NAT and operate it as a pure router.
    • rkrzewski's avatar
      rkrzewski
      Guide
      You are right. I do have port forwarding set up for TCP/22 -> 192.168.1.10:22. This is the reason of destination IP rewriting I didn't understand.
      I don't need or NAT or firewalling bewneen LAN and WAN interafaces of WNDR4300 because it's located inside a trusted network (except WiFi access, of course). If I understand correctly stock firmware won't allow me to do that. Welp, time to read up on DD-WRT then :)
      Thanks a lot for your help!
      • TheEther's avatar
        TheEther
        Guru
        If you don't need your WNDR4300 to operate as a router, then convert it to an AP.  This will eliminate the 192.168.1.0/24 subnet.  Update A's static route for 192.168.123.0/24 to point directly at B.
        The easy way to enable AP mode is to use ADVANCED > Advanced Setup > Wireless AP.  Tip: Ignore the instructions and avoid the WAN port.  The WAN<->LAN path is very slow.
