SethVictus
Jan 13, 2016Aspirant
Strange Ping spikes on local LAN with JWNR2000
Router model: Netgear JWNR2000 Firmware version: V1.0.0.7_1.0.6 Tested OS's: windows 10, linux raspbian distro. Since a couple of days my router has been behaving rather strange, even on wired...
- Jan 13, 2016
It's possible that it's because it's old.
Try to bypass to further isolate this problem.
If your connection is stable with your modem then definitely it's the router.
You can try to reflash the firmware then hard reset after.
If you get the same result, it's time to get a new one.
doraemon
Jan 13, 2016Prodigy
- SethVictusJan 13, 2016Aspirant
No problems with the desktop running directly on the modum. Resetting the router every now and then helps but the problem always returns. I'm too lazy to reflash my router so I guess ill be getting a new one. Thank you for the information.
