SethVictus's avatar
SethVictus
Strange Ping spikes on local LAN with JWNR2000
Router model: Netgear JWNR2000 Firmware version:  V1.0.0.7_1.0.6 Tested OS's: windows 10, linux raspbian distro.   Since a couple of days my router has been behaving rather strange, even on wired...
  • doraemon's avatar
    Jan 13, 2016
    It's possible that it's because it's old.
    Try to bypass to further isolate this problem.
    If your connection is stable with your modem then definitely it's the router.
    You can try to reflash the firmware then hard reset after.
    If you get the same result, it's time to get a new one.
