albertje's avatar
albertje
suddenly slower connections
Hello,
I had for 2 to 3 years 150mbit dowloadspeed al the time and now for a few weeks it drops to 130mbit.
nothing has changed.
any ideas?
  • Hi albertje,
    1. What is the firmware version of the router?
    2. Is the wired connection affected?
    3. Does the issue persist on both bands (2.4GHz and 5GHz)?
    4. Are all your wireless devices affected?
    5. Have you tried resetting the device?
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi albertje,
    Dexter
    Community Team
    • albertje's avatar
      albertje
      1. What is the firmware version of the router? The Newest
      2. Is the wired connection affected? don't now yet, but its ok in modem from provider
      3. Does the issue persist on both bands (2.4GHz and 5GHz)? I only use 5
      4. Are all your wireless devices affected? don't now
      5. Have you tried resetting the device? when i do that do i need to reinstal everything? i already turned power off and on
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi albertje,
        1. Please check if the wired connection is affected.
        2. Please check if your other wireless devices are affected when available for isolation.
        3. If the issue persists, we recommend doing a factory reset then reconfigure the settings. You may may find the link below helpful.
        http://kb.netgear.com/app/answers/detail/a_id/9665
        Dexter
        Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi albertje,
      You are welcome. Glad to know it is working fine now.
      Dexter
      Community Team
