kelley2100's avatar
kelley2100
switched computers, now router won't work, this device is blocked by access control in the router
Hello, I have had this wireless router for about three months and it worked fine. The main computer it was set up on is about 7 years old. I have a new computer which was added to the network without any problems, as well as several other devices. Today I decided it was time to start using the newer computer as the main one and so I switched them and hooked up the router and modem to the newer computer. Now I can't connect to the wireless router at all and get this message: "this device is blocked by access control in the router". How do I fix this or set up a new network using the newere computer as the main hub of the network? I'm using Windows 7 Professional. Thanks.
  • Retired_Member's avatar
    Retired_Member
    Dec 01, 2015
    I would start over only because it's easier than guessing what you did at some point. Push reset until power led flashes and use defaults found on router label. Locate the manual and read it too to gain a better understanding.
    Retired_Member
    • kelley2100's avatar
      kelley2100
      Thanks for the suggestion. Netgear Support gave me the same advice and it worked. Thanks for your help.
