bmellow2
Dec 07, 2016Aspirant
Treadmill causes router to reset to factory defaults
I recently got a treadmill desk on which I put a TV, Blu Ray player and powered speakers. I have had a problem where my router will reset to factory defaults if I use the treadmill more than about 2...
- Dec 07, 2016
I am going to try moving the UPS to a circuit in another room using an extension cable. There is only one circuit in that room. I didn't have time to try that this morning. I was just wondering if anyone else had seen this behavior.
Thanks
ElaineM
Dec 07, 2016NETGEAR Employee Retired
- bmellow2Dec 07, 2016Aspirant
Thanks
- ElaineMDec 07, 2016NETGEAR Employee Retired
No problem. If it happens again, try to check other outlet which may be in a different circuit breaker.
To be honest, this is my first time hearing it.
