bmellow2
Dec 07, 2016Aspirant
Treadmill causes router to reset to factory defaults
I recently got a treadmill desk on which I put a TV, Blu Ray player and powered speakers. I have had a problem where my router will reset to factory defaults if I use the treadmill more than about 2...
- Dec 07, 2016
I am going to try moving the UPS to a circuit in another room using an extension cable. There is only one circuit in that room. I didn't have time to try that this morning. I was just wondering if anyone else had seen this behavior.
Thanks
bmellow2
Thanks
ElaineM
Dec 07, 2016NETGEAR Employee Retired
No problem. If it happens again, try to check other outlet which may be in a different circuit breaker.
To be honest, this is my first time hearing it.
