jthomas666's avatar
jthomas666
Follower
Oct 31, 2016
Trying to block Roblox
I have a WNDR3400V3 wifi router, firmware version V1.0.1.4_1.0.52.   I'm trying to block Roblox. I have blocked the site on the security page, and if I type in roblox, it's properly blocked.  Howev...
  • Retired_Member's avatar
    Retired_Member
    Nov 01, 2016
    HTTPS sites cannot be blocked BUT you can block HTTPS under block services a little extreme but will definitely ruin there day. Setup or add user rule select HTTPS and use IP you want to block....use address reservation to assign same IP or IP range you want to block
