lozswioklo's avatar
lozswioklo
Trying to configure D6200 modem router for iinet NBN
Hi , hoping someone can point us in the right direction.
Struggling to configure our netgear modem router to work with iinet NBN. Just seems like we have settings we are supposed to set for iinet but can't find the location of the settings in Netgear Genie. Spent over hour on phone to iinet trying to set it up together to no avail. It seems like there is only old screenshots of network genie floating around online that don't match up with what we are seeing on routerlogin.net.
Anyone had similar experience?
NBN HFC
  • Hi, just wanted to say thanks - Firmware was what was causing us grief, we weren't seeing the new NBN fields in the outdated Netgear Genie. Your message gave me enough of a hint to track down what was wrong.
    Anyone else who has a similar issue, ask your Internet Provider for details more than once (as originally they gave us the wrong login info), upgrade the Firmware if you don't see the settings you need to change.
    :smileyhappy:
  • > Model: D6200|Dual Band 11ac ADSL Modem Router
       Firmware version?
    > [...] seems like we have settings we are supposed to set for iinet but
    > can't find the location of the settings in Netgear Genie. [...]
       For the non-psychics in your audience, could you offer any clues as
    to what these "settings we are supposed to set for iinet" might be?
    • lozswioklo's avatar
      lozswioklo
      Hi, yep sorry
      Device: Netgear D6200 DSL Modem Router
      _ _ _ _ _ _ _
      routerlogin.net
      Netgear Genie D6200 firmware: v1.1.00.09_1.00.09
      Tried genie autowizard a few times, not working. So tried configuring under advanced tab.
      _ _ _ _ _ _ _
      iinet supplied config instructions:
      - WAN interface: VDSL
      - WAN type: PPPoE
      - VLAN ID: 2
      - Encapsulation: PPPoE
      - login name : supplied
      - password: supplied
      - Idle timeout: always on
      - IP address: get dynamically
      - DNS: get auto from IPS
      - NAT: enable
      - Router: use default
      In network genie I can't seem to find:
      - WAN type: PPPoE
      - VLAN ID: 2
      _ _ _ _ _ _ _
      Under advanced home tab, the little status tiles are currently:
      Green tick: router information , wireless settings 2.4ghz, wireless settings 5.0ghz
      Red cross : Internet Port
      Yellow alert: guest wireless settings 2.4ghz, guest wireless settings 5.0ghz
      _ _ _ _ _ _ _
      X (red cross) internet port
      Mac address: filled out
      IP address: 0.0.0.0
      Active connection: PPPoE
      IP subset mask: 0.0.0.0
      Domain name server: 0.0.0.0
        lozswioklo
        :smileyhappy:
