Yato
Feb 20, 2017Aspirant
Trying to turn my router into a Switch (But cannot access it)
Hi, I am struggling with my router, and I cannot figure out what to do with it. I have a different modem, and it only has one ethernet port. So I Was hopeing to turn my old wifi adapter into an switc...
- Feb 20, 2017
What router are you using?
If I read your posting you have a new modem with a single lan port.
1 connect the lan port of the modem to the Internet port of the router
2 connect the wired lan ports of the two computers to the lan ports of the router there is your switch
3 can use the wifi of the router or turn it off the choice is yours you will still have the wired ports on most routers
William10a
Feb 20, 2017Master
- YatoFeb 20, 2017Aspirant
I realized I had simply overthought this entire thing, and was trying to do something copletly different than what I Wanted. I reset everything, and plugged them in normally and it worked just fine (after 4 hours of being dumb). I am very tired @-@
