luco41
Jun 25, 2017Aspirant
Trying to update firmware on router
Hello,i recently got an email from netgear and it says that i need to upgrade my router firmare, i looked on my netgear genie software to see if there is a firmware upgrade and it said that there isn...
- Jun 28, 2017
friendlytim The latest firmware version for WNR2000v3 is 1.1.2.14.
You can directly download it from here.
By default, the login is admin and password respectively, in all small letters.
If you're still unable to login, try other passwords that you may know but retain the username as admin.
Your last resort is to factory reset the router. Resetting will restore the settings of the router, so once you have reset the unit you will need to reconfigure the router.
luco41
Jun 26, 2017Aspirant
Okay thanks
friendlytim
I seem to be having the same problem but I have 2000v3. What do I do? I can't seem to get past the login to the router.
