katyireland
Oct 19, 2016Aspirant
Trying to update router firmware
Hi, I am trying to update my router firmware, and get as far as #3 in the installation instructions below, but then it asks for a username and password and I don't know what they are?
- Write down all the settings which you changed from the default values, since you may need to re-enter them manually.
- Using the Download Link below, download and extract the new firmware to a convenient place such as your desktop.
Download Link: http://www.downloads.netgear.com/files/GDC/WNDR3800/WNDR3800-V1.0.0.48.zip - Log in to the router using a Web browser. The URL is http://www.routerlogin.net.
- Click ADVANCED tab > Administration > Firmware Upgrade.
- Click Browse and find the file you just downloaded.
- Click Upload. Do not interrupt the upgrade while the router does this step.
Thank you, any advice appreciated!
katyireland wrote:Hi, I am trying to update my router firmware, and get as far as #3 in the installation instructions below, but then it asks for a username and password and I don't know what they are?
If you haven't changed it the default password is password
If that does not work, then someone has set a different password.
The way to get control back under those circumstances is to do a "factory reset" which will restore the default password.
Documentation here: WNDR3800 | Product | Support | NETGEAR
- katyirelandAspirant
Thank you so much, I've been going round in circles!
