tylerh13's avatar
tylerh13
Follower
May 11, 2022
turn off 5g on r6230
Can I turn off the wifi. I don't want the network hidden. I don't want wifi in my house.
Thanks
1 Reply
  • plemans's avatar
    There's a wifi on/off button on t he back of the router. You can push and hold it for 2 seconds to shut off wifi.
    Otherwise, you can disable the radio if you log in through the browser and go to advanced tab---->advanced setup----->wireless settings.
    You can find manuals here:
    https://www.netgear.com/support/product/R6230.aspx
