username99
Mar 14, 2016Tutor
Turn off wireless signal by schedule not working
R6050 router Turn off wireless signal by schedule not working. Also under the 'Security' tab the 'Schedule' option is greyed out.
- Mar 22, 2016
After resetting the router, turning off and on the AP mode and working for about 45 mins with netgear rep, I gave up.
Solution: sold the router and buying a litter higher priced linksys
username99
Mar 14, 2016Tutor
Also running latest firmware
- username99Mar 14, 2016Tutor
I also tried multiple browsers all have it greyed out.
- DexterJBMar 15, 2016NETGEAR Moderator
Hi @username99,
Have you tried resetting the router? If yes, I recommend performing a firmware reflash then reset and reconfigure the router. You may check the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
- Retired_MemberMar 15, 2016
If using AP Mode that function may not be available.
