CaptHastings
Apr 20, 2017Aspirant
Turning router on/off when wi-fi is not in use?
Hi all, I'm a bit new to using a WiFi router, and I have a general question. I would like to physically turn off the router when I'm not using WiFi, more to save electricity than anything else -...
- Apr 21, 2017
You won't save much electricity with something as "power light" as a modem, but you could do it.
The old idea that switching things on and off reduced their life doesn't stand up.
I would be more concerned that every time you turn it on it has to reconfigure itself and negotiate a link with the modem and the Internet. In theory it should be painless, but there have been too many questions here about routers that don't reconnect to make me confident that it will work every time.
michaelkenward
Apr 21, 2017Guru - Experienced User
- CaptHastingsApr 21, 2017Aspirant
Hi Mike,
Thanks for replying to my post.
I appreciate the input. I'll more than likely leave it on in that case.
Cheers,
Mike T.
