JeBo
Feb 07, 2017Aspirant
Unable to enable wireless
Dear forum users, I have the problem that it won't let me enable the "Enable Wireless Router Radio" option for my WNDR3700v2, so i cannot use my WiFi :( Am I missing an option, or is my router b...
- Feb 07, 2017
Try a factory reset. If that still doesn't work, try pushing the radio button one more time. If that still fails, then the router may be toast.
TheEther
Feb 07, 2017Guru
Is the wireless light on the router illuminated? If not, push the button for a few seconds to turn the radios on.
- JeBoFeb 07, 2017Aspirant
They are not, but the button on the device is not reacting and none of the options in the admin panel of the router is responding when i try to turn it on.
- TheEtherFeb 07, 2017Guru
Yeah tried all that :(
It happened after flashing to dd-wrt for openvpn option, but i reset it back to the netgear firmware and after that it went toast i geuss!
