JayInTech
Mar 20, 2023Tutor
Uncheck Allow Guests to see each other still lets them see wired LAN
R6400v2 I finally was able to scan my Guest Network and realized that Unchecking this box in the Guest Network setup only applies to Wi-Fi connections. Any hardwired LAN connections from the Router...
Mar 20, 2023Guru - Experienced User
So even though you have this disabled, Guest Network devices can still access and ping LAN ethernet connections or sources?
