aalexandrebeta
Mar 08, 2017Master
Universal HDD format to use
Hi guys, Sorry to bother you again, but I was woundering how and witch format and partition type you recommand to be able to use the same USB HDD to operate on Windows, Mac, Linux and NG routers....
- Mar 08, 2017
aalexandrebeta wrote:
Hi guys,
Well, there is no perfect answer for this combination.
-NTFS is read only on the Mac
-HFS can't be read on windows
-OSX and windows can't read ext
That leaves FAT32 perhaps. But the file size max of 2GB is a showstopper for HD movies or other larger files (for instance PC image backups).
If you have this particular combination, I suggest trying paragon on either the Windows or Mac (possibly both) to bridge the gap.
Mar 08, 2017Guru - Experienced User
Hi guys,
- William10aMar 08, 2017Master
If ready shear had version of a format that it could decode to match the computer system you could have three different os's on your computers and still read and write the hard drive.
- aalexandrebetaMar 08, 2017Master
"If ready shear had version" Can you send me the link on that program?
Linux is the best sstem where you can do all of the above!
I wish netgear would do it. It sounds like the best solve for so many attached hard drives issues have.
