aalexandrebeta
Mar 08, 2017Master
Universal HDD format to use
Hi guys, Sorry to bother you again, but I was woundering how and witch format and partition type you recommand to be able to use the same USB HDD to operate on Windows, Mac, Linux and NG routers....
- Mar 08, 2017
aalexandrebeta wrote:
Hi guys,
Well, there is no perfect answer for this combination.
-NTFS is read only on the Mac
-HFS can't be read on windows
-OSX and windows can't read ext
That leaves FAT32 perhaps. But the file size max of 2GB is a showstopper for HD movies or other larger files (for instance PC image backups).
If you have this particular combination, I suggest trying paragon on either the Windows or Mac (possibly both) to bridge the gap.
William10a
Mar 08, 2017Master
If ready shear had version of a format that it could decode to match the computer system you could have three different os's on your computers and still read and write the hard drive.
aalexandrebeta
Mar 08, 2017Master
"If ready shear had version" Can you send me the link on that program?
Linux is the best sstem where you can do all of the above!
- William10aMar 08, 2017Master
I wish netgear would do it. It sounds like the best solve for so many attached hard drives issues have.
- StephenBMar 10, 2017Guru - Experienced User
I'm rather confused on exactly that the "it" is that you want Netgear to do.
In my opinion, they should add exFAT to the supported formats - it is read/write in both Windows and OSX.
