wally3333's avatar
wally3333
Follower
Mar 19, 2023
update Wireless Router (WNR1000v3)
How do i update my router above i can not use the app it is not for my unit . thank you very much
1 Reply
  • michaelkenward's avatar
    michaelkenward
    You want to update the firmware on your WNR1000v3?
    How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
    Be warned that this device first appeared in 2010, based on an original router from 2009. It has slow WiFi. (They don't come much slower than N150.) The Ethernet is back from the era of 100 Mbps.
    So don't expect much.
    The latest firmware dates back to July 2020.
