m_schmitt
Sep 05, 2018Initiate
UPnP still broken on R6400
UPnP stopped working on the R6400 as of a recent firmware upgrade; I'm thinking it was 1.0.1.42 in June.
1.0.1.44 is now out, and UPnP still doesn't work.
Am I correct in assuming that this is a known problem? And that it will be fixed some day?
UPnP is fixed by R6400 firmware version 1.0.1.46.
I presume this doesn't open exposure to WAN-side UPnP attacks.
- NMCEngineerAspirant
I have the same issue. UPnP does not work after the firmware upgrade. I had to use port forwarding to access my IP cameras. Also, the camera dns names no longer work. I have to now use the actual IP address of the router to access the cameras.
My firmware version is V1.0.1.42_1.0.28. I noticed there is a fix for the R6700. Any chance getting an update forR6400?
> [...] the camera dns names no longer work. I have to now use the
What are these "the camera dns names"? Are you saying that some DDNS
feature is not working, or what?
Does reverting to an older firmware version help?
- m_schmittInitiate
Thanks for the update.
