autigers1970
Nov 16, 2016Aspirant
USB attached storage with WNDR4500
 I have a Netgear WNDR4500 that has two USB ports on the back for USB attached storage or printers.  I have a new Seagate Expansion external USB hard drive I'd like to use with it to create network at...
- Retired_MemberNov 16, 2016
Drive's require resources, Router USB resources are limited, compared to a USB port on a PC when the 4500 was designed YEARS ago the hard drives were 250Gb or less....now drives average 4tb and a router designed years ago Doesn't have the resources required to support larger drives.
Retired_Member
Nov 16, 2016Use this guide to see which drives are compatible, I checked and your Seagate Expansion isn't listed.
autigers1970
Wow, that is a short list of hard drives that will work. Don't understand why any USB hard drive, properly formatted, won't connect.
- michaelkenwardNov 17, 2016Guru - Experienced User
What are "resources"?
Which resources does the drive need?
Is this a reference to power?
- Retired_MemberNov 17, 2016
Plug in Play is what most USB drives are. When plugged into a PC USB port the OS AKA Windows detects and then loads whatever software is needed. Router USB ports don't support Plug N Play fully and or have Limited software support, power & CPU
"Very few external hard drives actually require software to be installed into the computer directly, as most USB external hard drivers are what is known as plug and play, as in Windows will detect them automatically and install the required software. If necessary, however, install the software from the manufacturer"
