Chaya
Oct 09, 2016Aspirant
Using 120V in a 240v country
I'm wanting advise on using an 8 port switch purchased in US diwn in Argentina which is 240v. I have no issues with my laotops handling dual voltage. Are netgear devices set up for dual voltage? If no...
- Retired_MemberOct 09, 2016
I think it would be cheaper to buy a new switch in country..no NG does not sell adapters
Chaya
Thanks. I double checked the power adapter that comes with it and it is rated 110v to 240v
Argentina does not have the latest equipment. At least 2 years behind and double the price.
Thanks anyway for your advise.
Retired_Member
Oct 09, 2016you're welcome
