Mindfac1's avatar
Mindfac1
Follower
Aug 04, 2021
Using power line adapter
Just needed to ask is it possible to use power line adapters In two separate buildings on same property?
  • > [...] is it possible to use power line adapters In two separate
       To communicate between the two buildings?  Might depend on how power
    is distributed to the two buildings.  I'd need to run the experiment.
       You might get/find better information sooner in a more appropriate
    forum:
          https://community.netgear.com/t5/x/bd-p/home-powerline
  • michaelkenward's avatar
    michaelkenward
    I have done this. It works. But the speeds are poor. Depending on how far apart the buildings are, a wifi link might be better.
    In my case the two buildings are about 10 metres apart. They run from the same mains inlet from the power company but the buildings have separate mains circuits and fuse boxes and all the associated circuit breakers. I can get a Powerline connection to work, but speeds drop down from around 60 Mbps to 5 Mbps.
    You might do better if your mains circuits are simpler. My electrician is a stickler for safety and won't do anything that is against the rules.
    You might get more on this subject in the appropriate section:
    Powerline Networking - NETGEAR Communities
    That's where Powerline uswers hang out.
