jlbice01's avatar
jlbice01
Using R6300v2 with ATT wireless home phone and internet MF279
I'm looking for advice or help in configuring a Netgear R6300v2 router with AT&T's wireless home phone and internet service. The AT&T device model number is MF279. It has an 1 ethernet port on the back and built in wireless 2.4GHz and 5GHz connections. The problem is it only allows a total of 20 wireless devices between the two spectrums which can be used up pretty quickly. There is also the issue of the Wi-Fi signal not being as strong as the Netgear's. Placement of the MF279 also is also determined by the cellular signal strength which is not neccessarily good for Wi-Fi placement in our house.
Any help would be appreciated.
  • antinode wrote:
    > [...] Placement of the MF279 also is also determined by the cellular
    > our house.
       If you can run a cable to a better place, then configuring the
    R6300v2 as a wireless access point might help.  Visit
    http://netgear.com/support , put in your model number, and look for
    Documentation.  Get the User Manual.  Look for "Wireless Access Point".
       For another possibility without the cable connection, look for "Set
    Up the Router in Bridge Mode".
    Now with it set up as a "Wireless Access Point", will that allow the wired portion of the R6300v2 to run as an ethernet switch? Is there an additional setting for that?
  • > [...] Placement of the MF279 also is also determined by the cellular
    > our house.
    • jlbice01's avatar
      jlbice01
      > our house.
      • antinode's avatar
        antinode
        Guru
           It should.  In WAP mode, the R6300v2 should act as a simple network
        switch (with wireless capability), and that includes the LAN ports.
        I'll admit that the term "wireless access point" can be misleading, but
        that's what it's generally called.  "Network switch with wireless
        capability" is more accurate, but cumbersome.
           Nothing to be set.
