HangingOut
Mar 25, 2024Follower
Using R6350 - AC1750 router with a Hard Disk Drive to run the Logitech Media Server
Can I connect the Netgear R6350 - AC1750 to my current modem/router with an ethernet cable and use it with a USB attached Hard Disk Drive loaded with the Logitech Media Server to provide server suppo...
michaelkenward
Mar 26, 2024Guru - Experienced User
HangingOut wrote:
Can I connect the Netgear R6350 - AC1750 to my current modem/router with an ethernet cable and use it with a USB attached Hard Disk Drive loaded with the Logitech Media Server to provide server support for my Logitect Squeezebox?
Unlikely. The USB ports on the R6350 have two uses.You can plug in some "dumb" USB storage or you can add a printer to your network.
