m43999
Jun 15, 2016Aspirant
VPN connects but no IP address for remote network
I have enabled VPN on the firewall and created the configuration files. At remote site i have downloaded the OpenVPN client and installed the software. The config files are copied to the appropriat...
DaneA
Jun 16, 2016NETGEAR Employee Retired
Hi m43999,
Welcome to the community! :)
What is the brand and model of the VPN firewall you are using? If ever it is a NETGEAR VPN Firewall, what is the current firmware version of it?
DaneA
NETGEAR Community Team
- m43999Jun 20, 2016Aspirant
Current Firmware Version V1.0.0.2_1.0.1
- ElaineMJun 20, 2016NETGEAR Employee Retired
m43999 Can you go ahead and update the firmware of the router?
You may download the firmware and follow the instructions from this link.
Firmware updated to V1.0.0.26_10.0.26
VPN adapter no seems to get an appropriate IP address and access is established.
Thank you for the assistance.
