BillS68
May 24, 2018Star
VPNFilter malware
Hi,
Does anyone know what NetGear routers are affected by the VPNFilter malware that is out in the wild?
BillS68
May 24, 2018Star
Thanks Johnny :-)
michaelkenward
May 25, 2018Guru - Experienced User
Then there is the Netgear response:
Security Advisory for VPNFilter Malware on Some Routers | Answer | NETGEAR Support
- netpertMay 28, 2018Aspirant
Please follow the advice from Cisco/Talos. Seriously.
Netgear advice will really not help you. I seriously doubt they know what they are talking about. Just an upgrade will not help here if your device is already compromised. It is also laughable to see such advice when the exploit itself is unknown.
- BillS68May 29, 2018Star
Seriously, I know who's advice to rely on.
If everyone checked and updated their routers they would not be at risk of getting this Malware, as stated by Netgear.
I was only after the routers affected, not advice on what to do, after all I run a IT Security company.... :-)
- michaelkenwardMay 29, 2018Guru - Experienced User
I am well impressed, but remember that these messages are not private conversations. There are ordinary mortals here who don't have PhDs in computer security.
