sbailey12's avatar
sbailey12
Vulnerability ID: NON-2015-0211 on my WNDR4500v3 router
I use Avast interenet security and it says my router is vulnerable. I click the details and ID: NON-2015-0211 shows. How do I fix this? I already made sure my router has the latest firmware.
  • ElaineM's avatar
    ElaineM
    Jun 01, 2016
    wadial Kindly make sure that you have the latest firmware installed and change the default login password of your router.
    Once done, run the Avast again and it should all be good.
