StVeronus's avatar
StVeronus
WAC104 Can't reset after bridge mode
I have a WAC104 that was in Bridge Mode.  I reset the primary router already (R6220).  This AP doesn't want to reset.  Every time I try, it goes back to broadcasting the bridged SSIDs.  So I can't get to the GUI and the reset button is no use. I have pushed the button for 10, 20, and 30 seconds.  I have tried pushing the button before applying power as well.  I have also tried to flash it with the nmrpflash tool, but it fails after uploading the firmware image.  It gets stuck at Received keep-alive request (45). And then doesn't go any further.  I have adjusted the -T option to 1800, but that doesn't help.  Any other tricks to get this AP back?
  • plemans's avatar
    Try setting the R6220 back up how it was so the WAC104 can connect to it. Then you should be able to log into it and reset it via the menu
    • StVeronus's avatar
      StVeronus
      Thanks Plemans.  I put the repeater's MAC into the router and saved it.  I'm able to connect to the network on the old SSID and password, but it is different than what is configured for the router now.  I can't seem to find the web interface for the repeater to connect and configure it.  It isn't responding on 192.168.0.100.  I tried to scan the network/dhcp logs for the MAC, but didn't see it.
      • plemans's avatar
        did you change the router's ip address?
        Check what the R6220's current ip address is. Your r6220 and the wac need to be in the same subnet
