emacpa9's avatar
emacpa9
Website for logging in to my netgear router
I have a netgear wireless router.  I would like to login to my router but do not know the website to use.  Thanks for any help you can provide.
  • routerlogin.com or routerlogin.net.  Either should work.  You can also use the router's LAN IP address.  It will be the same IP address as the default gateway on any device connected to the router.
    • emacpa9's avatar
      emacpa9
      Thanks very much.  I was able to log in.  Cheers!
