Belznickel53
Sep 20, 2016Aspirant
WEP or WPA2?
I don't know if my router is equipped with WEP - how can I find out ? If it does have WEP, can it be reset for WPA2 ? I'm not very tech-savvy, but I want to be sure I have the highest level of n...
- Sep 21, 2016
Wierd.. It happend to me also. Thry this link: https://www.netgear.com/support/product/WNDR3400v2.aspx - scroll down to the bottom, on left..
Belznickel53
Sep 21, 2016Aspirant
Thank you so much - but when I clicked on your LINK, I got an error message and I can't go forward from there.
Can you send me the link some other way ?
Thanks again.
netwrks
Sep 21, 2016Master
