elloellothere
Nov 01, 2015Aspirant
What am I doing wrong? Opening a port on my wireless router.
Hi!
I'm trying to open a port on my router, so my home network can be access externally.
What am I doing wrong with the setup? I've done the setups in instructions, but my port is still closed.
Example of what I've done :
Added a firewall rule to port 445 : http://oi68.tinypic.com/14xfe5h.jpg
Port Forwarding setup : http://oi63.tinypic.com/2hfi3aw.jpg
But port is still closed : http://oi63.tinypic.com/2n0ioma.jpg
Welcome to the community, elloellothere
What's the exact model number and version of your router?
Do you have the latest firmware installed on the router?
Did you try factory reset?
When you bypass the router, will this port work?
Just want to make sure that your ISP is not blocking such port.
Looking forward to your response.
- ElaineMNETGEAR Employee Retired
- elloellothereAspirant
ISP was blocking the port! /thank you :)
