pumpichank's avatar
pumpichank
Luminary
Oct 29, 2016
What does "use other operation mode" mean?
On the Advanced Wireless Settings page, there a cryptic option under the WPS Settings.  It says "use other operation mode".  There is no documentation in the help section that I can see, and I've not been able to find anything on this on the website.  What does this option actually *do*?
  • Do you try to use WPS? What are you trying to do any way?
    • pumpichank's avatar
      pumpichank
      Luminary
      I actually want to completely disable WPS, but the point of this question was different.  There's an option in the admin screens that really isn't documented anywhere and it pretty obscurely labeled.  I'm mostly curious -- what does this option *do*?
      • Retired_Member's avatar
        Retired_Member
        Ap mode or repeater if available
