pharmerphil
Aug 15, 2018Aspirant
What is the maximum MBPS the N750 can handle?
I use Charter/Spectrum for my internet service provider. They recently upgraded the base MBPS to 100 from 60. When I do a speed test, it shows my download to be 68 MBPS, not the base 100 MBPS. When I...
- Aug 15, 2018
Thank you for responding. I would recommend to run a speed test with the device wired directly to the modem. If you're still getting the same speeds I would suggest contacting your ISP as you may need to upgrade your modem.
Christian
Christian_R
Aug 15, 2018NETGEAR Employee Retired
Hi pharmerphil,
How are you running the speed test, wired or wireless? Could you also provide the model number to the modem you're using.
Thanks,
Christian
pharmerphil
Christian, I am running the speed test "wired", as "wired" works best in my concrete walled "berm home". The modem was supplied by Charter/Spectrum. It is an Arris TM1602 & is about 2 yrs. old. Thanks.
- Christian_RAug 15, 2018NETGEAR Employee Retired
Christian
- pharmerphilAug 15, 2018Aspirant
Thanks Christian.
