pharmerphil
Aug 15, 2018Aspirant
What is the maximum MBPS the N750 can handle?
I use Charter/Spectrum for my internet service provider. They recently upgraded the base MBPS to 100 from 60. When I do a speed test, it shows my download to be 68 MBPS, not the base 100 MBPS. When I...
- Aug 15, 2018
Thank you for responding. I would recommend to run a speed test with the device wired directly to the modem. If you're still getting the same speeds I would suggest contacting your ISP as you may need to upgrade your modem.
Christian
pharmerphil
Christian, I am running the speed test "wired", as "wired" works best in my concrete walled "berm home". The modem was supplied by Charter/Spectrum. It is an Arris TM1602 & is about 2 yrs. old. Thanks.
Christian_R
Aug 15, 2018NETGEAR Employee Retired
Christian
- pharmerphilAug 15, 2018Aspirant
Thanks Christian.
