Gian2097
Oct 18, 2016Aspirant
What to do? Router? Please help
Hi, im currently buying a xbox one and to connect to the wifi i know that my wifi (dorm wifi) doesnt work, (i searched the ways it worked but im not sure, and for others reasons too i want a router) s...
- Oct 20, 2016
patfan0315
Oct 27, 2016Aspirant
no help to me I don't have a nighthawk 1900 wifi extender I seen u have to have that one to use the full capacity of the genie app I bought a netgear ac1200 ex 6200 wifi extender I apparently bought the wrong one I can't get to the settings or set it up since I've had the extender frustration it sucks
- David_JOct 27, 2016NETGEAR Expert
Hello Patfan0315
What seems to be the issue here? Are you struggling to connect to an outside wifi source with your EX6200? which is what this post is about.
I see you have posted on another forum referencing Wrong extender again about a WNR3500Lv
2? why is it the wrong extender, I need more details if I am to help you. You are probably better creating your own post than posting under others as it can cause confusion to those reading. You have purchased an EX6200 that much is clear, you seem to be struggling to set it up. Have you contacted US Netgear support?
or have you typed How to set up my EX6200 into google? The link below will guide you to an easy how to setup your EX6200 walkthrough.
If you believe your EX6200 is faulty then please contact US support to verify its failure and organise a replacement.
- patfan0315Oct 27, 2016Aspirant
it's not allowing me to set up my router been online for like 3 days with this I did the wps that's the only way I can use my extender can't set anything up can't do my extender or router nothing it's not as easy as it is stated in the video that's for sure I'm tired of being online with this setting up stuff tired of wasting my time hours for no progress of setting up for something that is stated to be easy
Hello Patfan0315
when you say it isn't letting you set up your router or extender.
Please elaborate.
Which router do you have? how is the extender interfering with this?
when you say you can't set up the Extender, what is happening? are you connecting into the extender via your laptop with a cable? you are not connecting the extender and router via a cable are you?
I understand you are frustrated but right now you are just commenting what is not happening without providing me any detail in order to help get you a resolution.
If you are connecting via WPS then this means the extender works, so what else do you need setting up from here?
I am still confused as to exactly what your issue is here, you have not stated you cannot connect you just have mentioned that it won't let you setup, what does 'setup' .
Now that you have mentioned the router I need to understand what model this is, is it NETGEAR?
