rkamarowski
Oct 07, 2025Aspirant
Where can I find the driver for AC1750 R6400
I need to find the network driver for the AC1750 R6400. Can anyone help?
Routers Do NOT have drivers.
WiFi and Ethernet adpaters have drivers. Refer to your PC Mfr or WiFI/Ethernet chip set brand/Mfr for drivers for there products.
- rkamarowskiAspirant
I meant, where on my Windows 11 PC can I find it???
- wcalifasProdigy
Do you mean you can't find it on your wifi list of available networks? Or if you're already connected to it via wifi you just open a browser and type 192.168.1.1, or http://www.routerlogin.net and it will ask you for your login credentials you made when you first set it up. Hope that helps.
Thank you.
Good Luck.
