rkamarowski's avatar
rkamarowski
Where can I find the driver for AC1750 R6400
I need to find the network driver for the AC1750 R6400. Can anyone help?
  • Routers Do NOT have drivers.
    WiFi and Ethernet adpaters have drivers. Refer to your PC Mfr or WiFI/Ethernet chip set brand/Mfr for drivers for there products.
  • CrimpOn's avatar
    CrimpOn
    rkamarowski wrote:
    where on my Windows 11 PC can I find it?
    This depends on how the PC is designed to connect to the router:
    • When using an Ethernet cable, a symbol appears in the lower right part of the screen:
    • When connecting to the router WiFi network, there will be a WiFi symbol in the lower right. Clicking on that symbol will display a list of available WiFi networks.  Choose the appropriate SSID ("name"), enter the password, and Connect.
  • FURRYe38's avatar
