maxarch's avatar
maxarch
which model of router have a wifi on/off button
i am looking to know witch are routter have a on/off swich for the wifi like this model
NETGEAR Wireless-N 150 DSL
  • Retired_Member's avatar
    Retired_Member
    Aug 04, 2016
    Most routers have a wifi button to turn on and off wifi.
    Pick a router you're interested in then locate the manual and check it.
    Retired_Member
  • michaelkenward's avatar
    michaelkenward
    That is not a Netgear model. It is a wifi standard.
    So do what searay suggests.
    Decide on what you want the router to do, find a model that has those features, then check that it has an off/off switch for the wifi.
    • maxarch's avatar
      maxarch
      I know I can go on the control panel  with my computer and turn on and off the Wifi. What I meet it a physical button on  the case that you can press to switch on and off the WIFI signal. For the moment I have a D-Link dir-615 router,  I can turn on and off  by going to the control panel change the setting reset the modem wait 1 min that it reboots. I want an easier methode.like the model NETGEAR Wireless-N 150 DSL have a physical button on the case.
        Retired_Member
        Read my post again slowy..............
