onwegkarl
Oct 22, 2022Follower
Which Netgear router buy?
Hi there, i have virgin media 100mbps contact and hub3 as main router. From that i run cat7 cable to living room downstairs, where is netgear r6220 with tv and home cinema hanged on. I have anothe...
Oct 22, 2022Guru - Experienced User
Your budget and your expectations are a little out of line.
If you're wanting triband and wifi 6 for that price, you might need to watch for something like the RBK750 thats refurbished/renewed. That might get you in that window. Your other option is if your using a wired backhaul, a dual band system like the SXK30 would give you the same performance using a wired backhaul
