onwegkarl
Oct 22, 2022Follower
Which Netgear router buy?
Hi there, i have virgin media 100mbps contact and hub3 as main router. From that i run cat7 cable to living room downstairs, where is netgear r6220 with tv and home cinema hanged on. I have anothe...
michaelkenward
Oct 22, 2022Guru - Experienced User
You seem to be inviting problems.
Virgin usually supplies modem/routers. Unless you have put that into modem-only (bridge) mode, piling on a second router can cause problems. Adding a third could be even more interesting.
If you just want better wifi, look into wifi extenders. Fr the TV, you could invetsigate Powerline Ethernet and turn our mains circuit into wired Ethernet.
