Stormyblue's avatar
Stormyblue
Initiate
Aug 26, 2015
Why does my range extender not turn off when my router does
We bought a DGND3300v2 router and configured it to turn off at 10pm and come back on at 7am.   We then bought a XVN5001 Powerline 500 WiFi Access Point.   The issue is this - the router turns off...
  • netwrks's avatar
    Aug 26, 2015
    They are two separate devices.. Meaning, one does not turn off the other. And if all you have done is turn off the radios on the DGND3300, then you can still access the Interent, connecting via wifi, to the Internet, because the XVN5001 is physically connected (via ethernet cable) to the DGND3300. There doesn't seem to be much to configure on the XVN5001. Best option is to unplug the XVN5001, or, disconnect the Ethernet cable to the AP on the DGND3300.
