toao's avatar
toao
Why won't my printer connect?
My HP Deskjet 3520 works great when I wirelessly connect it to my AT&T router.  I am changing service and am trying to connect it to my Netgear WNDR 3400 and my cable modem.  I have gone into my HP software and changed the wireless settings.  The HP wireless setup on my computer recognizes the SSID for my Netgear network.  When I log in to my Netgear router manager and look under attached devices, it lists the printer however, my computer doesn't recognize the printer being attached.  In control panel: printers it says that printer is offline.  Basically, when my computer and printer settings are connected to the AT&T modem it works, when my computer and printer settings are connected to the Netgear modem and cable router it doesn't.  Can anyone help? Please!!
  • It took me forever, but it was actually pretty simple.  I simply had to uncheck the box for wireless isolation on my router manager.  I just lucked up and tried this and it worked!
  • Rerun the Add Printer wizard on your computer. Make sure your printer is on when you do this. Once you have completed this, you can safely remove the old printer instance from Devices and Printers.
    • toao's avatar
      toao
      When I try to add a printer in control panel, and I try to find a network printer, it won't find my printer.
      • toao's avatar
        toao
