hennrike
Feb 22, 2016Aspirant
Wifi 2.4Ghz very slow on my R6250 Router
Last week I bought a R6250 Wifi Router, and I have problems with 2.4Gb wifi connections. They are too slow. I have 300 Mb (download) and 30 Mb (upload) with my ISP provider. With 5Ghz Wifi connec...
- Feb 24, 2016
Hi Dexter,
Last night I did only a few tests.
I've changed the wifi channel to value 1, and the results seems to be better: donwload speed between 25 and 42 MB and upload speed between 20 and 30 MB.
I'll continue some days with this configuration.
Regards
DexterJB
Feb 22, 2016NETGEAR Moderator
Hi @hennrike,
1. Do all wireless devices that connect to the 2.4GHz experience the issue?
2. Have you tried resetting the router? If not, you may refer to the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/9665
3. Have you tried changing the wireless channel?
http://kb.netgear.com/app/answers/detail/a_id/23783
Dexter
Community Team
hennrike
Thanks Dexter,
I respond you:
1: Yes, all devices experience the same issue with the 2.4GHz. I've been testing with a Huawei P8 Lite, Moto G First Generation, and iPhone 6
2: No, I have no try resetting the router. I'll try tonight
3: No, the wirless channel is in auto mode. I'll try change the channel tonight.
Regards
