loz63
Nov 13, 2016Follower
wifi channel
I have a netgear wifi router model WNDR3700v5 which untill yesterday was working fine , it offered 2 channels from new , a 2.4 ghz and a 5ghz. my set up for the last 9 months has been on the 2.4 channel. this channel seems to have disapeared from all appliances that use it , eg my phones,( nothing is now connected to wifi ) the 5 ghz channel remains and i have connected to this with no problems so far. i have just dl the latest firmware and installed it . my netgenie app says the channel is still there and ok it just seems to be undiscoverable. hoping someone has an idea to fix this
cheers Laurie
- Retired_MemberNov 14, 2016
forget the app use web browser and login to router or
Press reset until power LED flashes the default SSID should then be visible ( see router Label ) if not replace router
1 Reply
- Retired_Member
