edmark
Apr 10, 2018Aspirant
Wifi connected but remote computer doesn't access internet
Wifi shows connected and computer shows on the network map, but my remote, wireless computer cannot access the internet, How can I fix it?
- Apr 12, 2018
Thanks for your advice. I got into my wife's network settings, they asked for my security password and then it connected to the Wifi network. Thanks so much for your help.
michaelkenward
Apr 12, 2018Guru - Experienced User
OK. I asked because "remote" has a special meaning in network talk. It refers to getting into your network from the other side of the planet, for example, not from within the same local network. There are various settings for that in routers, but we can ignore that.
In this case your wife has a problem connecting to the local wifi network.
If her computer is running Windows, she may have to look at the network settings there. One common problem is that her PC thinks it is on a "public" network.
What happens when she tries to establish a wifi connection? Have you tried using the Network Troubleshooter in Windows?
We still don't have much information to go on. For example, we don't know if anything can connect to the wifi network. Do you have smartphones or tablets that connect happily to the router?
We need to know that to confirm that your wifi network is set up properly and that the problem is at the client end, your wife's PC.
edmark
Apr 12, 2018Aspirant
